Preguntas del examen de certificación de abap
Buenos días
He encontrado unas cuantas preguntas sobre el examen de certificación de ABAP espero les sean útiles
ABAP CERTIFICATION QUESTIONS
  1. If a table does not have MANDT as part of the primary key, it is ____.
    A: A structure
    B: Invalid
    C: Client-independent
    D: Not mandatory
  2. In regard to CALL, which of the following is NOT a valid statement?
    A: CALL FUNCTION
    B: CALL SCREEN
    C: CALL TRANSACTION
    D: CALL PROGRAM
  3. Name the type of ABAP Dictionary table that has these characteristics:
Same number of fields as the database table
Same name as database table
Maps 1:1 to database table
A: Pooled
B: Cluster
C: Transparent
D: View
  1. An event starts with an event keyword and ends with:
    A: Program execution.
    B: END-OF-EVENT.
    C: Another event keyword.
    D: END-EVENT.
  2. What is the system field for the current date?
    A: SY-DATUM
    B: SY-DATE
    C: SY-DATID
    D: SY-SDATE
  3. The following code indicates:
SELECT fld1 fld2 FROM tab1 APPENDING TABLE itab
WHERE fld1 IN sfld1.
A: Add rows to the existing rows of itab.
B: Add rows to itab after first deleting any existing rows of itab.
C: Select rows from tab1 for matching itab entries.
D: Nothing, this is a syntax error.
  1. You may change the following data object as shown below so that it equals 3.14.
    CONSTANTS: PI type P decimals 2 value ‘3.1’.
PI = ‘3.14’.
A: True
B: False
  1. The SAP service that ensures data integrity by handling locking is called:
    A: Update
    B: Dialog
    C: Enqueue/Dequeue
    D: Spool
  2. Which of these sentences most accurately describes the GET VBAK LATE. event?
    A: This event is processed before the second time the GET VBAK event is processed.
    B: This event is processed after all occurrences of the GET VBAK event are completed.
    C: This event will only be processed after the user has selected a basic list row.
    D: This event is only processed if no records are selected from table VBAK.
  3. Which of the following is not a true statement in regard to a hashed internal table type?
    A: Its key must always be UNIQUE.
    B: May only be accessed by its key.
    C: Response time for accessing a row depends on the number of entries in the table.
    D: Declared using internal table type HASHED TABLE.
  4. TO include database-specific SQL statements within an ABAP program, code them between:
    A: NATIVE SQL_ENDNATIVE.
    B: DB SQL_ENDDB.
    C: SELECT_ENDSELECT.
    D: EXEC SQL_ENDEXEC.
  5. To measure how long a block of code runs, use the ABAP statement:
    A: GET TIME .
    B: SET TIME FIELD .
    C: GET RUN TIME FIELD .
    D: SET CURSOR FIELD .
  6. When a secondary list is being processed, the data of the basic list is available by default.
    A: True
    B: False
  7. Given:
DATA: BEGIN OF itab OCCURS 10,
qty type I,
END OF itab.
DO 25 TIMES. itab-qty = sy-index. APPEND itab. ENDDO.
LOOP AT itab WHERE qty > 10.
WRITE: /1 itab-qty.
ENDLOOP.
This will result in:
A: Output of only those itab rows with a qty field less than 10
B: Output of the first 10 itab rows with a qty field greater than 10
C: A syntax error
D: None of the above
  1. After a DESCRIBE TABLE statement SY-TFILL will contain
    A: The number of rows in the internal table.
    B: The current OCCURS value.
    C: Zero, if the table contains one or more rows.
    D: The length of the internal table row structure.
  2. You may declare your own internal table type using the TYPES keyword.
    A: True
    B: False
  3. After adding rows to an internal table with COLLECT, you should avoid adding more rows with APPEND.
    A: True
    B: False
  4. Which of the following is not a component of control break processing when looping at an internal table?
    A: AT START OF
    B: AT FIRST
    C: AT LAST
    D: AT NEW
  5. A dictionary table is made available for use within an ABAP program via the TABLES statement.
    A: True
    B: False
  6. Which of the following would be best for hiding further selection criteria until a function is chosen?
    A: AT NEW SELECTION-SCREEN
    B: SELECTION-SCREEN AT LINE-SELECTION
    C: SUBMIT SELECTION-SCREEN
    D: CALL SELECTION-SCREEN
  7. What must you code in the flow logic to prevent a module from being called unless a field contains a non-initial value (as determined by its data type)?
    A: ON INPUT
    B: CHAIN
    C: FIELD
    D: ON REQUEST
  8. The AT USER-COMMAND event is triggered by functions defined in the ____.
    A: screen painter
    B: ABAP report
    C: menu painter status
    D: ABAP Dictionary
  9. In regard to a function group, which of the following is NOT a true statement?
    A: Combines similar function modules.
    B: Shares global data with all its function modules.
    C: Exists within the ABAP workbench as an include program.
    D: Shares subroutines with all its function modules.
  10. In regard to SET PF-STATUS, you can deactivate unwanted function codes by using ____.
    A: EXCLUDING
    B: IMMEDIATELY
    C: WITHOUT
    D: HIDE
  11. In regard to data transported in PAI when the FIELD statement is used, which of the following is NOT a true statement?
    A: Fields in PBO are transported directly from PAI.
    B: Fields with identical names are transported to the ABAP side.
    C: Fields not defined in FIELD statements are transported first.
    D: Fields that are defined in FIELD statements are transported when their corresponding module is called.
  12. The order in which an event appears in the ABAP code determines when the event is processed.
    A: True
    B: False
  13. A field declared as type T has the following internal representation:
    A: SSMMHH
    B: HHMMSS
    C: MMHHSS
    D: HHSSMM
  14. Which of the following is NOT a component of the default standard ABAP report header?
    A: Date and Time
    B: List title
    C: Page number
    D: Underline
  15. Assuming a pushbutton with function code ‘FUNC’ is available in the toolbar of a list report, what event is processed when the button is clicked?
    A: AT USER-COMMAND.
    B: AT PFn.
    C: AT SELECTION-SCREEN.
    D: END-OF-SELECTION.
  16. In regard to field selection, what option of the SELECT statement is required?
    A: FOR ALL ENTRIES
    B: WHERE
    C: INTO
    D: MOVE-CORRESPONDING
  17. The following program outputs what?
report zjgtest1
write: /1 ‘Ready_’.
PARAMETER: test.
INITIALIZATION.
write: /1 ‘Set_’.
START-OF-SELECTION.
write: /1 ‘GO!!’.
A: Set_ GO!! (each on its own line)
B: Set_ Ready_ GO!! (all on their own lines)
C: Ready_ GO!! (each on its own line)
D: Ready_ Set_ GO!! (all on their own lines)
  1. To declare a selection criterion that does not appear on the selection screen, use:
    A: NO-DISPLAY
    B: INVISIBLE
    C: MODIF ID
    D: OBLIGATORY
  2. An internal table that is nested within another internal table should not contain a header line.
    A: True
    B: False
  3. What is output by the following code?
DATA: BEGIN OF itab OCCURS 0, letter type c, END OF itab.
itab-letter = ‘A’. APPEND itab. itab-letter = ‘B’. APPEND itab.
itab-letter = ‘C’. APPEND itab. itab-letter = ‘D’. APPEND itab.
LOOP AT itab.
SY-TABIX = 2.
WRITE itab-letter.
EXIT.
ENDLOOP.
A: A
B: A B C D
C: B
D: B C D
  1. To select all database entries for a certain WHERE clause into an internal table in one step, use
    A: SELECT_INTO TABLE itab_
    B: SELECT_INTO itab_
    C: SELECT_APPENDING itab
    D: SELECT_itab_
  2. After a successful SELECT statement, what does SY-SUBRC equal?
    A: 0
    B: 4
    C: 8
    D: Null
  3. This selection screen syntax forces the user to input a value:
    A: REQUIRED-ENTRY
    B: OBLIGATORY
    C: DEFAULT
    D: SELECTION-SCREEN EXCLUDE
  4. If the following code results in a syntax error, the remedy is:
DATA: itab TYPE SORTED TABLE OF rec_type WITH UNIQUE KEY field1
WITH HEADER LINE.
itab-field1 = ‘Company’. itab-field2 = ‘1234’. INSERT TABLE itab.
itab-field1 = ‘Bank’. itab-field2 = ‘ABC’. INSERT TABLE itab.
SORT itab.
LOOP AT itab.
write: /1 itab-field1, itab-field2.
ENDLOOP.
A: There is no syntax error here
B: Remove the SORT statement
C: Change INSERT to APPEND
D: Add a WHERE clause to the loop
  1. If this code results in an error, the remedy is:
SELECT fld1 fld2 FROM tab1 WHERE fld3 = pfld3.
WRITE: /1 tab1-fld1, tab1-fld2.
ENDSELECT.
A: Add a SY-SUBRC check.
B: Change the WHERE clause to use fld1 or fld2.
C: Remove the /1 from the WRITE statement.
D: Add INTO (tab1-fld1, tab1-fld2).
  1. When modifying an internal table within LOOP AT itab. _ ENDLOOP. you must include an index number.
    A: True
    B: False
  2. To allow the user to enter values on the screen for a list field, use:
    A: OPEN LINE.
    B: SET CURSOR FIELD.
    C: WRITE fld AS INPUT FIELD.
    D: FORMAT INPUT ON.
  3. Before a function module may be tested, it must first be:
    A: Linked
    B: Authorized
    C: Released
    D: Active
  4. To include a field on your screen that is not in the ABAP Dictionary, which include program should contain the data declaration for the field?
    A: PBO module include program
    B: TOP include program
    C: PAI module include program
    D: Subroutine include program
  5. If a table contains many duplicate values for a field, minimize the number of records returned by using this SELECT statement addition.
    A: MIN
    B: ORDER BY
    C: DISTINCT
    D: DELETE
  6. The system internal table used for dynamic screen modification is named:
    A: ITAB
    B: SCREEN
    C: MODTAB
    D: SMOD
  7. Within the source code of a function module, errors are handled via the keyword:
    A: EXCEPTION
    B: RAISE
    C: STOP
    D: ABEND
  8. Which system field contains the contents of a selected line?
    A: SY-CUCOL
    B: SY-LILLI
    C: SY-CUROW
    D: SY-LISEL
  9. The following statement writes what type of data object?
    WRITE: /1 ‘Total Amount:’.
    A: Text literal
    B: Text variable
    C: In-code comment
    D: Text integer
  10. For the code below, second_field is of what data type?
    DATA: first_field type P, second_field like first_field.
    A: P
    B: C
    C: N
    D: D
  11. Which of the following describes the internal representation of a type D data object?
    A: DDMMYYYY
    B: YYYYDDMM
    C: MMDDYYYY
    D: YYYYMMDD
  12. A BDC program is used for all of the following except:
    A: Downloading data to a local file
    B: Data interfaces between SAP and external systems
    C: Initial data transfer
    D: Entering a large amount of data
  13. In regard to PERFORM, which of the following is NOT a true statement?
    A: May be used within a subroutine.
    B: Requires actual parameters.
    C: Recursive calls are allowed in ABAP.
    D: Can call a subroutine in another program.
  14. What is the transaction code for the ABAP Editor?
    A: SE11
    B: SE38
    C: SE36
    D: SE16
  15. In regard to HIDE, which of the following is NOT a true statement?
    A: Saves the contents of variables in relation to a list line’s row number.
    B: The hidden variables must be output on a list line.
    C: The HIDE area is retrieved when using the READ LINE statement.
    D: The HIDE area is retrieved when an interactive event is triggered.
  16. Database locks are sufficient in a multi-user environment.
    A: True
    B: False
  17. The complete technical definition of a table field is determined by the field’s:
    A: Domain
    B: Field name
    C: Data type
    D: Data element
  18. In regard to LEAVE, which of the following is NOT a true statement?
    A: May be used to return immediately to a calling program.
    B: May be used to stop the current loop pass and get the next.
    C: May be used to start a new transaction.
    D: May be used to go to the next screen.
  19. The following code indicates:
SELECT fld6 fld3 fld2 fld1 FROM tab1 INTO CORRESPONDING FIELDS OF TABLE itab
WHERE fld3 = pfld3.
A: The order of the fields in itab does not matter.
B: Fill the header line of itab, but not the body.
C: Table itab can only contain fields also in table tab1.
D: None of the above.
  1. The ABAP statement below indicates that the program should continue with the next line of code if the internal table itab:
CHECK NOT itab[] IS INITIAL.
A: Contains no rows
B: Contains at least one row
C: Has a header line
D: Has an empty header line
  1. What will be output by the following code?
DATA: BEGIN OF itab OCCURS 0, fval type i, END OF itab.
itab-fval = 1. APPEND itab.
itab-fval = 2. APPEND itab.
FREE itab.
WRITE: /1 itab-fval.
A: 2
B: 0
C: blank
D: 1
  1. To allow the user to enter a range of values on a selection screen, use the ABAP keyword:
    A: DATA.
    B: RANGES.
    C: PARAMETERS.
    D: SELECT-OPTIONS.
  2. If an internal table is declared without a header line, what else must you declare to work with the table’s rows?
    A: Another internal table with a header line.
    B: A work area with the same structure as the internal table.
    C: An internal table type using the TYPES statement.
    D: A PARAMETER.
  3. Assuming an internal table contains 2000 entries, how many entries will it have after the following line of code is executed?
DELETE itab FROM 1500 TO 1700.
A: This is a syntax error.
B: 1801
C: 1800
D: 1799
  1. To remove lines from a database table, use ____.
    A: UPDATE
    B: MODIFY
    C: ERASE
    D: DELETE
  2. All of the following may be performed using SET CURSOR except:
    A: Move the cursor to a specific field on a list.
    B: Move the cursor to a specific list line.
    C: Move the cursor to a specific pushbutton, activating that function.
    D: Move the cursor to a specific row and column on a list.
  3. When is it optional to pass an actual parameter to a required formal parameter of a function module?
    A: The actual parameter is type C.
    B: The formal parameter contains a default value.
    C: The formal parameter’s “Reference” attribute is turned on.
    D: It is never optional.
  4. Coding two INITIALIZATION events will cause a syntax error.
    A: True
    B: False
  5. Adding a COMMIT WORK statement between SELECT_ENDSELECT is a good method for improving performance.
    A: True
    B: False
  6. To save information on a list line for use after the line is selected, use this keyword.
    A: APPEND
    B: EXPORT
    C: WRITE
    D: HIDE
  7. To bypass automatic field input checks, include this in PAI.
    A: AT EXIT-COMMAND
    B: ON INPUT
    C: ON REQUEST
    D: LEAVE TO SCREEN 0.
  8. Within a function module’s source code, if the MESSAGE_RAISING statement is executed, all of the following system fields are filled automatically except:
    A: SY-MSGTY
    B: SY-MSGNO
    C: SY-MSGV1
    D: SY-MSGWA
REPORT ZLISTTST.
START-OF-SELECTION.
WRITE: text-001.
FORMAT HOTSPOT ON.
WRITE: text-002.
FORMAT HOTSPOT OFF.
AT LINE-SELECTION.
WRITE / text-003.
A: Text-002 may not be selected.
B: The value of text-002 is stored in a special memory area.
C: Text-002 may be clicked once to trigger the output of text-003.
  1. The ____ type of ABAP Dictionary view consists of one or more transparent tables and may be accessed by an ABAP program using Open SQL.
    A: Database view
    B: Projection view
    C: Help view
    D: Entity view
  2. A concrete field is associated with a field-symbol via ABAP keyword
    A: MOVE
    B: WRITE
    C: ASSIGN
    D: VALUE
  3. The output for the following code will be:
report zabaprg.
DATA: char_field type C.
char_field = ‘ABAP data’.
WRITE char_field.
A: ABAP data
B: A
C: Nothing, there is a syntax error
  1. Page footers are coded in the event:
    A: TOP-OF-PAGE.
    B: END-OF-SELECTION.
    C: NEW-PAGE.
    D: END-OF-PAGE.
  2. The event AT SELECTION-SCREEN OUTPUT. occurs before the selection screen is displayed and is the best event for assigning default values to selection criteria.
    A: True
    B: False
  3. The TABLES statement declares a data object.
    A: True
    B: False
  4. Assuming tab1-fld7 is not a key field, how can you prevent reading all the table rows?
SELECT fld1 fld2 fld3 FROM tab1 INTO (fld4, fld5, fld6)
WHERE fld7 = pfld7.
WRITE: /1 fld4, fld5, fld6.
ENDSELECT.
A: Take fld7 out of the WHERE clause.
B: Create an index in the ABAP Dictionary for tab1-fld7.
C: Use INTO TABLE instead of just INTO.
D: Take the WRITE statement out of the SELECT_ENDSELECT.
  1. Which of the following is NOT a required attribute when creating an ABAP program?
    A: Application
    B: Title
    C: Status
    D: Type
  2. When creating a transparent table in the ABAP Dictionary, which step automatically creates the table in the underlying database?
    A: Adding technical settings to the table
    B: Checking the table syntax
    C: Saving the table
    D: Activating the table
  3. Within the ABAP program attributes, Type = 1 represents:
    A: INCLUDE program
    B: Online program
    C: Module pool
    D: Function group
    E: Subroutine pool
  4. If this code results in an error, the remedy is:
SELECT fld1 SUM( fld1 ) FROM tab1 INTO_
A: Remove the spaces from SUM( fld1 ).
B: Move SUM( fld1 ) before fld1.
C: Add GROUP BY f1.
D: Change to SUM( DISTINCT f1 ).
  1. Which keyword adds rows to an internal table while accumulating numeric values?
    A: INSERT
    B: APPEND
    C: COLLECT
    D: GROUP
  2. Assuming itab has a header line, what will be output by the following code?
READ TABLE itab INDEX 3 TRANSPORTING field1.
WRITE: /1 itab-field1, itab-field2.
A: The contents of the third row’s itab-field1.
B: The contents of the third row’s itab-field1 and itab-field2.
C: The contents of the third row’s itab-field2.
D: Nothing.
  1. The following code indicates:
SELECTION-SCREEN BEGIN OF BLOCK B1.
PARAMETERS: myparam(10) type C,
Myparam2(10) type N,
SELECTION-SCREEN END OF BLOCK.
A: Draw a box around myparam and myparam2 on the selection screen.
B: Allow myparam and myparam2 to be ready for input during an error dialog.
C: Do not display myparam and myparam2 on the selection screen.
D: Display myparam and myparam2 only if both fields have default values.
  1. Which statement will sort the data of an internal table with fields FRUIT, QTY, and PRICE so that it appears as follows?
FRUIT QTY PRICE
Apples 12 22.50
Apples 9 18.25
Oranges 15 17.35
Bananas 20 10.20
Bananas 15 6.89
Bananas 5 2.75
A: SORT itab DESCENDING BY QTY PRICE.
B: SORT itab BY PRICE FRUIT.
C: SORT itab.
D: SORT itab BY PRICE DESCENDING.
  1. Which keyword adds a line anywhere within an internal table?
    A: APPEND
    B: MODIFY
    C: ADD
    D: INSERT
  2. To read a single line of an internal table, use the following:
    A: LOOP AT itab. _ ENDLOOP.
    B: READ itab.
    C: SELECT SINGLE * FROM itab.
    D: READ TABLE itab.
  3. Which Open SQL statement should not be used with cluster databases?
    A: UPDATE
    B: MODIFY
    C: DELETE
    D: INSERT
  5. This flow logic statement is used to make multiple fields open for input after an error or warning message.
    A: GROUP
    B: FIELD-GROUP
    C: CHAIN
    D: LOOP AT SCREEN
  6. Given:
PERFORM subroutine USING var.
The var field is known as what type of parameter?
A: Formal
B: Actual
C: Static
D: Value
10 Me gusta
Hola Ricardo, gracias por tu aporte.
Pero tendrás la fuente de dónde salieron las preguntas?
Para así saber de qué año son por ejemplo.
Ayudan mucho para poder saber en que temas indagar.
viendo esta pregunta yo diría que antigua aunque podría estar relacionado con hana
Gracias @Ricardo_Agude, viendo las pregunta creo que sacar la certificación no es algo del otro mundo.
Interesante @Ricardo_Agude gracias.
Gracias por el aporte @Ricardo_Agude, en su momento lo imprimire y lo pegare en mi refri!
:sweat_smile: :wave:t4:
Alguien que se haya preparado el examen de certificación puede decir si es complicado de aprobar? Son todas tipo test? Gracias de antemano.
Muchas gracias amigo, interesante información para saber en que indagar.
