¿Como puedo instalar sap en opensuse?
Hola les escribo porque estoy teniendo muchos problemas al instalar sap 7.51 en opensuse 42.3 en una vm de virtualbox.
ya hice un port forwading, ya instalé uuidd, cambié el hostname y asigné en hosts
hostname: vhcalnplci
en hosts:
10.0.2.15 vhcalnplci vhcalnplci.dummy.nodomain
pero aún asi termina la instalación e incluso tras reintentar con este error:
INFO 2021-06-19 15:10:51.592 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/modlib/iaxxbjsmod.cpp:83] id=modlib.jslib.childAppReturn
Execution of the command “/tmp/sapinst_exe.5427.1624129743/jre/bin/java -classpath /tmp/sapinst_instdir/NW73/SBC/STANDARD/sybhelper.jar:sybhelper.jar -Xmx256m portcheck 4901 4902 4903 4904” finished with return code 0. Output:
checking port 4901
could bind port 4901
could not connect to port 4901
checking port 4902
could bind port 4902
could not connect to port 4902
checking port 4903
could bind port 4903
could not connect to port 4903
checking port 4904
could bind port 4904
could not connect to port 4904
INFO 2021-06-19 15:10:51.805 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/modlib/iaxxbjsmod.cpp:83] id=modlib.jslib.childAppReturn
checking port 4901
checking port 4902
checking port 4903
checking port 4904
INFO 2021-06-19 15:10:51.990 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/syslib/process/syuxccuren.cpp:546] id=syslib.process.currentProcessEnv.cwdSuccessful CSyCurrentProcessEnvironmentImpl::setWorkingDirectory(const CSyPath& /tmp/sapinst_instdir/NW73/SBC/STANDARD)
Working directory changed to /tmp/sapinst_instdir/NW73/SBC/STANDARD.
INFO 2021-06-19 15:10:52.074 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/sapinst/CSiStepExecute.cpp:980] id=controller.executeStep
Execute step syb_dialog_dbuser_password of component |offlineadjustment_dialogs|ind|ind|ind|ind|0|0|offlineadjustment_db_post|ind|ind|ind|ind|db_post|0|syb_rename_db_post_dia|ind|ind|ind|ind|syb|0|NW_SYB_DB_REN|ind|ind|ind|ind|syb2|0
ERROR 2021-06-19 15:10:52.255 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/modlib/iaxxbjsmod.cpp:83] id=modlib.jslib.caughtException errno=MUT-03025
Caught ESAPinstException in module call: Validator of step |offlineadjustment_dialogs|ind|ind|ind|ind|0|0|offlineadjustment_db_post|ind|ind|ind|ind|db_post|0|syb_rename_db_post_dia|ind|ind|ind|ind|syb|0|NW_SYB_DB_REN|ind|ind|ind|ind|syb2|0|syb_dialog_dbuser_password reports an error:
To solve that problem start the installation without using SAPINST_START_GUI option…
ERROR 2021-06-19 15:10:52.331 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/sapinst/CSiStepExecute.cpp:1117] id=controller.stepExecuted errno=FCO-00011
The step syb_dialog_dbuser_password with step key |offlineadjustment_dialogs|ind|ind|ind|ind|0|0|offlineadjustment_db_post|ind|ind|ind|ind|db_post|0|syb_rename_db_post_dia|ind|ind|ind|ind|syb|0|NW_SYB_DB_REN|ind|ind|ind|ind|syb2|0|syb_dialog_dbuser_password was executed with status ERROR ( Last error reported by the step: Caught ESAPinstException in module call: Validator of step |offlineadjustment_dialogs|ind|ind|ind|ind|0|0|offlineadjustment_db_post|ind|ind|ind|ind|db_post|0|syb_rename_db_post_dia|ind|ind|ind|ind|syb|0|NW_SYB_DB_REN|ind|ind|ind|ind|syb2|0|syb_dialog_dbuser_password reports an error:
To solve that problem start the installation without using SAPINST_START_GUI option…).
INFO 2021-06-19 15:10:52.591 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/syslib/filesystem/syuxcpath.cpp:443] id=syslib.filesystem.creatingFile CSyPath::createFile()
Creating file /tmp/sapinst_instdir/NW73/SBC/STANDARD/INSTANA.XML.
INFO 2021-06-19 15:10:52.701 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/syslib/filesystem/syuxcpath.cpp:443] id=syslib.filesystem.creatingFile CSyPath::createFile()
Creating file /tmp/sapinst_instdir/NW73/SBC/STANDARD/instslana.xml.
a /tmp/sapinst_exe.5427.1624129743/dev_selfex.out
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/control.xml
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/controllerKdbClient.dmp
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/date.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/df.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/hostname.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/instana.xsl
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/keydb.xml
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/rpm.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/rsecssfx.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/sapinst.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/sapinst_dev.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/sapinst_loginquirer.log
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/start_dir.cd
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/stepKeydbClient.dmp
a /tmp/sapinst_instdir/NW73/SBC/STANDARD/syslib_priv.log
INFO 2021-06-19 15:10:53.130 (root/sapinst) (startInstallation) [/bas/749_REL/bc_749_REL/src/ins/SAPINST/impl/src/syslib/process/syuxccuren.cpp:546] id=syslib.process.currentProcessEnv.cwdSuccessful CSyCurrentProcessEnvironmentImpl::setWorkingDirectory(const CSyPath& /tmp/sapinst_instdir/NW73/SBC/STANDARD)
Abort execution because of
Step returns modlib.jslib.caughtException
Installation of NPL failed, please check logifiles in /tmp/sapinst_instdir for possible root cause.
No sé que más hacer. Ya hice una guia paso a paso y sigo sin poder tener sap instalado en una VM
