Buenos días,
Continuamente estoy leyendo acerca de los manuales oficiales de SAP para ABAP. Y me gustaría saber que diferencia hay entre TAW10/TAW12 y BC100/BC400. Es decir, cual interesa más para aprender ABAP?
Cristina
Buenos días,
Cristina
Son bastante “diferentes”
h_tps://training.sap.com/shop/course/taw10-abap-workbench-fundamentals-classroom-015-g-en/SAP NetWeaver Application Server fundamentals:
SAP Systems and SAP Applications Portfolio
SAPGUI and navigation in AS ABAP systems
System Core
Communication and integration technologies
ABAP Workbench Foundations:
ABAP program processing
ABAP Workbench tools
ABAP language basics, Open SQL
Modularization techniques
Complex data objects, structures and internal tables
Data modeling and data retrieval
Classic ABAP reports
Program analysis tools
Program calls and memory management
ABAP Dictionary:
Domains, data elements, structures
Transparent tables, pool tables and cluster tables
Input checks
Dictionary object dependencies
Changes in table structure
Views
Search helps
Classical UI programming:
Selection screens
Screens (dynpros)
https://training.sap.com/shop/course/bc100-introduction-to-programming-with-abap-classroom-015-us-enBasics of ABAP Programming
Developing a Simple ABAP Program
Introducing ABAP Syntax
Implementing a Simple Dialog
Customizing the ABAP Editor
Coding and Debugging in ABAP
Defining Simple Variables
Defining Text Symbols Performing Arithmetic Operations Using Simple Variables
Using System Variables
Debugging a Program
Creating an ABAP List
Processing Character Strings
Control Flow Structures in ABAP
Implementing Conditional Logic
Implementing Loops
Runtime Errors and Error Handling
Analyzing Runtime Errors
Implementing Error Handling
Additional ABAP Programming Techniques
Retrieving Data From the Database
Describing Modularization in ABAP
Using Function Modules
Para saber TAW12, y BC400, están los enlaces en la misma referencia de cada curso que te pasé anteriormente.
Saludos!
Pero entoces…para aprender ABAP cual es mejor… Parece mas interesante el BC100 y BC411, no?
Cristina
El “nivel” te indica para qué es el curso.
Los TAW dicen “Nivel: Consultant Academy Training”, y para los BC, dice: “Nivel: Details, Configuration & Transaction”
Eso dependerá de qué y para qué estudies y pagues los montos de los cursos Cristina.
Si vas a certificar ABAP, vas a estar en un nivel de “Academia” para ser consultor ABAP, entonces se certifica con los TAW.
Y si no es mucha molestia…cual es más sugerente si eres desarrollador ABAP? No tengo interés de momento en sacarme ninguna certificación pero todo lo que me ayude a ampliar conocimientos sería de mucho interés.
Gracias !!
@Mario_Castano Si no sabes nada o sabes poco de abap, yo sugeriria este:
BC100
Introduction to Programming with ABAP
Ya que justamente es la introducción a programar en ABAP
Estoy viendo los contenidos y comentándolo con los compañeros, alguno de ellos tiene el bc402 que son evidentemente mas avanzados y parecen muy interesantes.
Además está el bc401 que contempla la programación orientada a objetos.
Estoy un poco perdido con las certificaciones, manuales, cursos…
Muchas gracias por las aclaraciones
Consulta, aqui alguien tiene los BC? o hay alguna manera de conseguirlos de manera gratuita? estoy iniciandome en abap y solo conocia los taw
Yo tambien estoy interesado en obtener documentacion para aprender ABAP. Realmente necesito ayuda en este tema, ya que como consultor SAP HCM se me dificulta encontrar trabajo si no poseo conocimientos en ABAP para configurar nomina o crear reportes, si alguien puede compartirme ya sea el BC100 o los TAW, se lo agradesco mucho, ya que es realmente urgente para mi consegirlos.
Hola meny212, soy nuevo, como te puedo comentar por MP?
@meny212 para compartir la informacion puedes conservarlo con @SidV
Y pues viendo la informacion que comentas Sidv, veo y yo como abap, que los BCXXX son mas como nociones tecnicas del propio entorno que es sap y los TAW son puramente tecnicos sobre el propio lenguaje abap pero ninguno de los 2 te va a enseñar a programar, programar es cuestion de logica y los principios de programacion los puedes conseguir en google sin ningun problema !!
Hola @PABB85 y @meny212 por favor lean este post.
Cualquier pregunta no duden en comentar.
Saludos (:
@meny212, @PABB85 y al resto, eviten sanciones…
Ya saben cómo se debe colaborar con la comunidad.
PD: @Cristina_Frai, ya está solucionado este tema? Marca la respuesta que más te haya ayudado, asi se cierra, se está desvirtuando
