Buenos dias,
Estan realizando una auditoria a mi empresa y me estan pidiendo un registro de los respaldos realizados a la base de datos y las restauraciones realizadas, entiendo que con una consulta al SQL se puede sacar un registro con esta informacion, el anterior encargado presentaba un registro pero yo no conozco mucho de sql, el format es:
select
bs.database_name as TargetDatabase
,bs.backup_start_date as Operation_Date
,cast(datediff(minute,bs.backup_start_date,bs.backup_finish_date)/60 as varchar) + ’ hours ’ +
cast(datediff(minute,bs.backup_start_date,bs.backup_finish_date)%60 as varchar) + ’ minutes ’ +
cast(datediff(second,bs.backup_start_date,bs.backup_finish_date)%60 as varchar) + ’ seconds’
as [Duration]
,cast(bs.backup_size/1024/1024 as decimal(22,2)) as [BackupSize(MB)]
,‘BACKUP’ as Operation_Type
,case bs.type
when ‘D’ then 'Database’
when ‘L’ then 'Log’
when ‘I’ then 'Differential’
end as BackupType
,bs.user_name as [User]
,bmf.physical_device_name as BackupFile
,bs.server_name as ServerOrigin
,bs.recovery_model
,bs.begins_log_chain
,bs.is_copy_only
,bms.software_name as BackupSoftware
from msdb.dbo.backupset bs
inner join msdb.dbo.backupmediaset bms
on bs.media_set_id = bms.media_set_id
inner join msdb.dbo.backupmediafamily bmf
on bms.media_set_id = bmf.media_set_id
where bs.database_name = db_name()
and bs.server_name = serverproperty(‘servername’)
union all
select
rh.destination_database_name
,rh.restore_date as operation_date
,‘Unknown’ as [Duration]
,‘RESTORE’ as Operation_Type
,case rh.restore_type
when ‘L’ then 'Log’
end as BackupType
,rh.user_name as [User]
,bs.recovery_model
,bs.is_copy_only
inner join msdb.dbo.restorehistory rh
on bs.backup_set_id = rh.backup_set_id
where rh.destination_database_name = db_name()
order by 2 desc
