Las preguntas mas comunes certificacion abap
Me gustaria crear este post para que entre todos podamos dejar las preguntas que nos hicieron o que hemos investigado para podernos certificar como abap
4 Me gusta
Va la primer página de uno que me pasaron, después si vemos que les sirve voy pegando el resto
  1. Which statements are allowed if you are working with an internal table of the
    type SORTED? (T/F)
    F- SORT
    F- APPEND
    F- MODIFY
    T- COLLECT
    T- READ
  2. Which of the following ABAP statements create a list for executable programs?
    (T/F)
    T- SKIP
    T- WRITE
    F- PERFORM
    F- CLEAR
    T- ULINE
  3. Which of the following statements are correct? (T/F)
  • You can select from several database tables using a database view or a join. T
  • A secondary index for non-key fields generally works like a primary index for
    key fields. T
  • A key field in a database table uniquely identifies a data record. T
  • The client field is a selective field and should therefore always be specified in
    the
    WHERE condition for SELECT. F
  • The OPEN SQL statements are converted into database-specific statements by
    the database interface. T
  1. What do you get when you refer to a client-specific transparent table in the
    Dictionary if you have a data definition with TABLES? (Single selection)
  • A structured work area (line). T
  • A field. F
  • An internal table. F
  1. In program P, the SUBMIT statement is used to call report R. How can you pass
    data from P to R? (T/F)
  • Using the SET/GET parameters. T
  • By passing parameters using additions in the SUBMIT statement. T
  • Using the ABAP memory. T
  • By declaring the data objects with the same name in both programs, using the
    DATA statement. F
  1. Which of the following statements about the SELECT statement are correct?
    (T/F)
  • With SELECT SINGLE access, the result is one data record maximum. T
  • The SELECT statement supports the return code (SY-SUBRC). T
  • With SELECT…ENDSELECT access. the result is one data record maximum. F
  • The SELECT statement always reads the data into the SAP memory first. F
  • With SELECT…INTO TABLE access, the result is one data record maximum. F
Mis dos centavos sobre este tema, pueden buscar más preguntas que otras personas (generalmente en ingles) han aportado aquí:
:arrow_right: http://www.daypo.com/buscar.php?t=abap
4 Me gusta
El siguiente de UDEMY también está bueno, aunque es de pago considero que vale mucho la pena:
Buenas! yo esyoy leyendo los manuales para preparar la certificación. Respecto a las preguntas, solo encuentro en inglés, alguno sabe si hay en castellano en algún sitio para poder practicar?
Un saludo y gracias!
