Query para sacar los Pagos Recibidos
Buenas estimados,
Por favor su ayuda necesito un query de pagos recibidos actualmente tengo uno pero no funciona de manera correcta ya que no saca todos los valores correctos.
O hay alguna otra forma de ver los pagos recibidos?
SELECT
	T0."DocNum",
	T0."CardCode",
	T0."CardName",
	T0."DocDate",
	T0."TrsfrAcct",
	T0."CheckAcct",
	T0."CashAcct",
	T0."DocTotal",
    T0."U_LS_MOTIVO",
    T0."Series",
    T0."U_SYP_PTCC",
    T2."DocNum",
    T2."DocDate",
    T2."DocTotal"
FROM "ORCT" T0
INNER JOIN "RCT2" T1 ON T0."DocEntry" = T1."DocNum"
INNER JOIN "OINV" T2 ON T1."DocEntry" = T2."DocEntry"
WHERE T0."Canceled"='N' and T2."DocDate" Between '[%1]' and '[%2]'
Recuerda formatear el código sql adecuadamente, por favor.
En este te lo he editado.
SELECT  T0."DocEntry",T0."CounterRef" as "Recibo",T1."InvoiceId",T0."DocDate" as "Fecha Recibo", T0."CardCode", T0."CardName", T0."DocCurr", T0."Comments",
		case when T1."InvoiceId" = 0
		then
			case when T0."DocCurr"='USD' then T0."DocTotalFC" else T0."DocTotal" end
		else 0 end as "Monto_Recibo"
		,T0."U_NoRet", T2."DocDate", T2."U_DoctoNo", T2."NumAtCard",
		case when T0."DocCurr"='USD' then T1."AppliedFC" else T1."SumApplied" end as "Monto_Aplicado",
		case when T0."DocCurr"='USD' then T2."DocTotalFC" else T2."DocTotal" end as "Total Factura",T0."DocType"
FROM ORCT T0
left JOIN RCT2 T1 ON T0."DocEntry" = T1."DocNum"
left join OINV T2 on T1."DocEntry"= T2."DocEntry"  and T1."InvType" =13
left join OCRD T3 on T0."CardCode"=T3."CardCode"
WHERE T0."DocDate" >= [%1] and  T0."DocDate" <= [%2] and  T0."Canceled" ='N'   and T0."DocType" = 'C' and T1."InvType" =13
union all
		then
		case when T0."DocCurr"='USD' then T1."AppliedFC"*-1 else T1."SumApplied"*-1 end as "Monto_Aplicado",
		case when T0."DocCurr"='USD' then T2."DocTotalFC"*-1 else T2."DocTotal"*-1 end as "Total Factura",T0."DocType"
FROM ORCT T0
left join orin T2 on T1."DocEntry"= T2."DocEntry"  and T1."InvType" =14
WHERE T0."DocDate" >= [%1] and  T0."DocDate" <= [%2] and  T0."Canceled" ='N'   and T0."DocType" = 'C' and T1."InvType" =14
ORDER BY "DocCurr", "DocEntry" ;
Por si te sirve de algo, este es mi codigo.
