Estimados buen dia. Quiero solicitar de su conocimiento. Tengo este query que es de un libro de compras.
DECLARE @FechaInicial AS DATETIME
DECLARE @FechaFinal AS DATETIME
SELECT @FechaInicial = T0.F_RefDate, @FechaFinal = T0.T_RefDate
FROM OFPR T0
WHERE T0.F_RefDate = '[%0]' AND T0.T_RefDate = '[%1]'
SET @FechaInicial = CONVERT(DATETIME, '[%0]', 112)
SET @FechaFinal = CONVERT(DATETIME, '[%1]', 112)
SELECT
A.DocNum,
ch.Cheque,
'OPCH' as Tabla,
a.TaxDate as Fecha_Contabilizacion,
CASE
WHEN A51.Seriesname LIKE '%F.Esp%' THEN 'FE'
WHEN B.U_TIPO = 'P' THEN 'PQ'
ELSE 'FAC'
END as Tipo,
A.CardName as 'CardName', -- Agregado CardName
CASE
WHEN A.Series = '64' THEN (SELECT CA.CardName FROM OCRD CA INNER JOIN PCH1 BA
ON CA.CardCode=BA.U_Proveedor AND CA.CardType='S' AND B.LineNum=Ba.LineNum AND Ba.DocEntry=B.DocEntry)
ELSE ISNULL(A1.U_NombreE, c.CardName)
END as 'Deudor/Acreedor',
CASE
WHEN A.Series = '64' THEN (SELECT CA.U_NIT FROM OCRD CA INNER JOIN PCH1 BA
ELSE ISNULL(A1.U_NIT, c.U_NIT)
END as 'NIT',
CASE
WHEN A.Series = '64' THEN 0 ELSE A.DocNum
END as NumeroDocumento,
CASE
WHEN A.Series = '64' THEN ISNULL(B.U_Serie , 'Error') ELSE A.U_Serie
END as Serie,
CASE
WHEN A.Series <> '64' THEN A.NumAtCard ELSE B.U_NumeroFc
END as NumeroReferencia,
SUM(CASE WHEN B.U_TIPO = 'B' THEN B.LineTotal ELSE 0 END) as Bien,
SUM(CASE WHEN B.U_TIPO = 'S' THEN B.LineTotal ELSE 0 END) as Servicio,
SUM(CASE WHEN B.U_TIPO = 'C' THEN B.LineTotal ELSE 0 END) as Combustible,
SUM(CASE WHEN B.U_TIPO IN ('E','P') THEN B.LineTotal ELSE 0 END) as Exento,
SUM(CASE WHEN B.U_TIPO = 'I' AND B.TaxOnly = 'Y' THEN B.Price ELSE 0 END) as Importacion,
SUM(CASE WHEN B.U_Tipo = 'I' AND B.TaxOnly = 'Y' THEN B.VatSum ELSE B.VatSum END) as IVA,
SUM(CASE WHEN B.U_TIPO IN ('B', 'S', 'C', 'E', 'P', 'I') THEN B.LineTotal ELSE 0 END + CASE WHEN B.U_Tipo = 'I' AND B.TaxOnly = 'Y' THEN B.VatSum ELSE B.VatSum END) as Total
FROM
PCH1 B
RIGHT JOIN OPCH A ON A.DocEntry = B.DocEntry
LEFT JOIN OCRD C ON A.CardCode = C.CardCode
LEFT JOIN NNM1 A51 ON A.series = A51.series
LEFT JOIN RPC1 B1 ON B.DocEntry = B1.BaseEntry AND B.ObjType = B1.BaseType AND B.LineNum = B1.BaseLine
LEFT JOIN ORPC B2 ON B1.DocEntry = B2.DocEntry
LEFT JOIN [@PROV] A1 ON A.U_Prov = A1.Code
LEFT OUTER JOIN (SELECT a.DocEntry, b.CheckNum as Cheque FROM VPM2 a LEFT OUTER JOIN VPM1 b ON a.DocNum = b.DocNum) ch ON A.Docnum = ch.docentry
WHERE
A.DocDate >= @FechaInicial
AND A.DocDate <= @FechaFinal
AND B.U_TIPO <> 'N'
AND A.DocSubType = '--'
AND ISNULL(B2.Series, 0) IN (-1, 0)
GROUP BY
A.TaxDate,
A.CardCode,
A.CardName,
C.U_NIT,
A.DocNum,
A.U_Serie,
A.Series,
A.NumAtCard,
A.U_Prov,
B.U_Tipo,
A51.seriesname,
C.QryGroup1,
A1.Name,
A1.U_NombreE,
A1.U_NIT,
B.U_Proveedor,
C.CardCode,
C.CardName,
B.U_NumeroFc,
B.U_Serie,
B.LineTotal,
B.LineNum,
B.DocEntry,
ch.cheque
UNION ALL
SELECT DISTINCT
A.DocNum as DocNum,
0,
'ORPC' as Tabla,
A.TaxDate as Fecha_Contabilizacion,
'NC' as Tipo,
CASE WHEN C.QryGroup1 = 'Y' THEN ISNULL(A1.U_NombreE, A1.Name) ELSE A.CardName END as 'Deudor/Acreedor',
CASE WHEN C.QryGroup1 = 'Y' THEN A1.U_NIT ELSE C.U_NIT END as 'NIT',
A.DocNum as NumeroDocumento,
A.U_Serie,
A.NumAtCard as NumeroReferencia,
SUM(CASE WHEN B.U_TIPO = 'B' THEN B.LineTotal * -1 ELSE 0 END) as Bien,
SUM(CASE WHEN B.U_TIPO = 'S' THEN B.LineTotal * -1 ELSE 0 END) as Servicio,
SUM(CASE WHEN B.U_TIPO = 'C' THEN B.LineTotal * -1 ELSE 0 END) as Combustible,
SUM(CASE WHEN B.U_TIPO IN ('E', 'P') THEN B.LineTotal * -1 ELSE 0 END) as Exento,
SUM(CASE WHEN B.U_TIPO = 'I' THEN 0 ELSE 0 END) as Importacion,
SUM(CASE WHEN B.U_Tipo = 'I' THEN B.LineTotal * -1 ELSE B.VatSum * -1 END) as IVA,
SUM(CASE WHEN B.U_TIPO IN ('B', 'S', 'C', 'E', 'P', 'I') THEN B.LineTotal * -1 ELSE 0 END + CASE WHEN B.U_Tipo = 'I' THEN B.LineTotal * -1 ELSE B.VatSum * -1 END) as Total
FROM
ORPC A
JOIN RPC1 B ON A.DocEntry = B.DocEntry
WHERE
AND B.U_TIPO <> 'N'
AND A.Series = 102
AND ISNULL(A.NumAtCard, '') <> ''
GROUP BY
A.TaxDate,
A.CardCode,
A.CardName,
C.U_NIT,
A.DocNum,
A.U_Serie,
A.NumAtCard,
C.QryGroup1,
A1.Name,
A1.U_NombreE,
A1.U_NIT;
Y me da esta informacion (imagen)
El problema es que, por ejemplo lo marcado es de una factura de gasolina, esta la registran en dos lineas. Una registra el valor de combustible y la otra el excento. Necesito que me unifique ese dato a una sola linea, guiandonos de que es el mismo numero de documento, lo mismo me pasa con facturas de energia electrica, que llevan un registro en servicio y el otro en exento.
Podrian ayudarme para modificar este query. De antemano les agradezco el apoyo.
