Temas sobre SWUE Y SWPR, ayuda
Tengo una super duda sobre temas en la SWIA, seguido marcan error, y ultimamente hay opcion de utilizar la SWPR o SWUE, sin embargo tengo dudas cual es la funcion exactamente de cada una, cuando una estrategia marca error dicen utilizar la SWPR pero al usarla dice que no se puede lanzar el evento.
y en el caso de SWUE dice evento generado pero la vdd no tengo idea de como es el proceso en general.
Alguien que pueda resolver mi duda??
No uso WF. Te cito:
SWPR - Workflow Restart after Error
Use this tool to restart any workflow instance after error. This tool can be used in this 2 situations, those are:
  1. After you have changed the container value manually using the SWI1 functionalities above, so that you can resume the workflow processing without waiting for the developer to finish rectifying the error, or
  2. After the developer finish rectifying the error, and re-transport it to the production.
SWPC - Workflow Restart after System Crash
Use this tool to restart any workflow instance that is hanging after server down or system crash. You can recognize this ‘hanging’ workflow instance by comparing the last work item status with the workflow instance status in table SWWWIHEAD. If the workflow status is still ‘STARTED’ where as the last work item status is ‘COMPLETED’ for more than several hours, most probably the workflow is hanging.
Fuente: h_tps://archive.sap.com/discussions/thread/3317063
